Can custom fonts be addred to Guru Pro ?
Also, is it possible NOT to have the Course Name in white outline added? I'd rather have course name on class advatar and headers
oracleweb1
Guru use the font applied by the template, You can customize the font family with your own by change the css in Guru.
Ninja Great. Not sure why it looked like it was not using site fonts But now it all looks right
On the second question--Do we have to have the name of the course automatically placed om the course header? I see a choice of top or bottom..but not to not have it there at all
oracleweb1
The name of the course will show on the header cover area in guru by default. Can you give me screenshot that explain better which exact option you are looking.
Sure , I have been playing iwth it so
https://tinyurl.com/ycglmgm7
and another
https://tinyurl.com/y8u74cup
I had to change things so the Course title can which is placed there by default can fit
a. Does the title have to be auto printed on the course cover?
b. Is the size of cover/avatar adjustable?
here are the avatars for the two above
https://tinyurl.com/yarupfx9
and
https://tinyurl.com/yaz78c3q
again Using the regular size doesn;t result in showing up properly in 2 across view. What do I need to do?
Even clearer i'd like to use this cover
I like making a course logo like that and using it for the cover
but if it has to have the title written I have to design them to have that in white like that
can that default be turned off in guru?
oracleweb1
The cover images load in the background of the container and change its size based on the content.
Its set as cover style http://prntscr.com/10fxzb6
https://ijoomlademo.com/index.php/ijoomla-extensions/guruPrograms/5-ijoomla-extensions/1-ijoomla-ad-agency
If its been set as responsive in this case for mobile view when the content height is more it can not fill the complete space that is why its set as cover.
The cover option on the course could not be off as it shows behind the main information of the course.
On Cover Photo and Avatar. So on the templates you have that use Guru.. They have large and r more square avatar photos for classes. A lot nicer when its not a tech class.. How is that done?
oracleweb1
All the covers load as background, May i know the URL of page so i can check it as example from demo ?
for example JA Sensie has different style for Guru as its template that has custom layout for it.
