Hello, I'm developing a Eng/Spanish site and believe I have done everything right in terms of setting up dual menus, content, templates, etc.
The problem is with the templates. If I assign the English menu to the English template, that's OK. I then assign the Spanish menu to the Spanish template, hit save and find the The English menu is now using the Spanish menu.
I've tried everything to get around this but no luck.
Would you mind having a look to see if you can fix this?
Thanks, JR
