On some pages with a table, when browser's window is small as for mobile device, part of table is out of the window.
See screenshot.
How is it possible to display everything is on table ?
Carine
See screenshot.
Carine
carine-k
Kindly check there is scroll bar at the bottom that will help you to see this content. as the table and content both can not fit in small size devices there is scrollbar show. http://prntscr.com/115au4p
Hi Pankaj,
So there's no way to fix that ?
Carine
Hi Pankaj,
OK I understand but how can I put texts in columns without table ?
Carine
carine-k
You can use Bootstrap classes
Example : https://bootstrapdocs.com/v2.3.2/docs/examples/fluid.html
In form of span 2, 4,6,8,10,12
Total span size in a row should not exceed 12.
Thanks Pankaj, I'll try this later.
Carine
