I'm trying to follow the instructions to install T4 as a test site to see how it works. I can't seem to find a quickstart download for this and the link to the video tutorial gets a 404. Also, when I've tried to search this forum (e.g. "t4 install"), often it times out and says it can't find anything, and throws up multiple error messages in red (anywhere from a few to dozens of them).
I created a brand new Joomla installation. I've never worked with the JA Extension Manager before, but I managed to install it, and have set it as default, and uploaded and updated both the T4 System Plugin and T4 Blank Template. But I'm not sure how to install the T4 Framework zip file. When I tried to do that through the regular Joomla Installation (Extensions > Manage > Install), the installation failed with: "Warning JInstaller: :Install: Can't find Joomla XML setup file. The Joomla package cannot be installed through the Extension Manager. Please use the Joomla! Update component to update Joomla."
The instructions on the Installation Instructions page don't seem to mention the 3rd installation file (t4-framework.zip) and the T4 tutorials are inaccessible as far as I can tell. So, I'm stuck. I'm hoping someone can help, and hopefully fix the problems in the forum search and the tutorial link.
Thanks in advance.
