Is it possible to add another module just under the Search module in this image I'm attaching? I would like to balance the dropdown menu item. Thanks.
patvandenbosche Hi yes you can use the same module position and publish a module it will display under search. You can use custom html module to create own style content.
Thanks, I tried that before contacting you, and it didn't work... until I increased the size of the space. I'm learning a lot with this template, lots of challenges, and finding out what I can do in Joomla. I appreciate all the help.
patvandenbosche Hi. Kindly publish a custom html module for test and u will see it. Heights depends on the content that you will show in that area. I tested it on your site already this is normal .
