We are using JA Eventcamp Template and latest Joomla Version 3.9.27.
We have been using the T4 System Plugin Version 1.0.5 and so far all was fine.
But when we install the latest version of T4 System Plugin 1.1.7, there are template issues with the sidebar menu and homepage is somewhat broken. The sidebar menu (off canvas) is always visible and not hidden (default) and cannot be closed (see screenshot)
I tried with lower versions of T4 System Plugin to understand which version introduced the issues first and was able to identify it. The issues started with version 1.0.6 ....
I have then re-installed previous version 1.0.5 and all is fine.
Can you please check and try to find the code that introduced the issues because we want to use latest version of the T4 System Plugin to be up-to-date but cannot use is under current circumstances.
