Hello
The submenus are not displayed in the menu bar anymore. What settings should I make to reactivate them?
Main menu : Accueil St-Brais
Best regards, Yanick
kinay Hi Kindly check it now, It is working fine. The js file you excluded in the template was defined wrong. I corrected that and it is working fine now.
Perfect, it works, but the problem persists once the menus "Commune" and "Règlements" are selected.
To help me understand my mistake, could you tell me how to fix this problem, which file it is?
Kind regards, Yanick
kinay Hi All menu items working fine now http://prntscr.com/1kag03c
