Hello it seems that Module previews does not work with T3 plugin 3.0.2 you can see here: https://educate.joomlatema.net/index.php?tp=1 Preview is enabled on Template settings. It works when you installed an older version eg. 2.7.6. Thanks
muratyil Hi The template you are using is not from us Please check the Plugin with our template as this product not belong to us. The support is limited for own products only.
What does it matter? You should focus on the issue. So here is your templates: 1-The one with T3 plugn 3.0.2 and module previews can not be seen : https://joomlatema.net/t3blank-1/?tp=1 2-The one with T3 plugn 2.7.6 and module previews can be seen : https://joomlatema.net/t3blank-2/?tp=1
It seems that after T3 2.7.7 version module previews can not be seen even it is enabled on template settings. On both sites above template previews are enabled.
muratyil What does it matter?
Hi It does matters as our support is limited for own products only. About this issue Please check you are using latest version of T3 bS3 blank template that is supported for Joomla 4 and latest T3 verison I tested it and it is working fine : http://prntscr.com/1rchj4i In quickstart installation as well : http://prntscr.com/1rchyzs
I have downloaded that quickstart https://prnt.sc/1rdjf31 it did not work but after upgrading t3 blank template it works now. The quickstart can be upgraded.
muratyil Thanks I will check the package and if found it will be fixed.
