T4 and Quix visual builder don't work together; here is what themexpert write to me :
The T4 system plugin does not allow Quix 4 to load. In the T4 1.0.7, we added a fix where Quix 4 is loading. So, we discourage the Financio template users from updating T4. However, we have requested the T4 team to allow Quix 4 builder. They did not fix it yet. We wish they would allow Quix 4.
Do you plan to fix it ?
Thanks for your answer
jean-Philippe Boillat
    Hi boillat
    I'm not quite sure where they sent the request yet.
    Could you share the details of the issue so we can check?
      saguaros
      I send you the credential where you can test the issue
      Actually it's working because I install the plugin v 1.0.7 ( see attachment)
      1. If you install the latest version of t4 plugin, the QUIX visual builder doesn't load ( but classical page works)
      2. this website is just a test website and is not in production, so feel free to make test
      Jean-Philippe
      Hi Jean-Philippe,
      Thanks for the info, I will take a backup of your site first and check it.
      2 months later
      It seems this issue isn't fixed as off yet. At least not with the T4 plugin for Joomla 4 with Quix 4.1.0.
      Do you intend to fix this issue on short term?
        As I can see that T4 2.0.8 version installed but Quix Builder is still working, could you clarify step by step to replicate the issue?
          saguaros
          It does show the pages on the front-end, but when you open a page in the Quix editor to edit it, it gives a completely blank page. The strange thing is that it doesn't show any erros in the logs. When selecting an other template without the T4 framework, the Quix editor works fine again.
          michcio29
          I did not, but I don't think that this layout setting will have any effect on the matter. When opening a page in the Quix editor to edit it, it gives a blank page without any html code at all. Just like when the display of php error is completly turned off. But in this case I have all error display and debuging options turned on, but It does not show anything.
            vdekieviet Could you create a new topic and share the login info of your site? I checked the site from Jean in this topic but it works fine.
              saguaros
              It is not possible to give you access to the site, because it's on a local testserver, with no external access to it. But perhabs you can recreate the circumstances. Ik tried it on an upgraded site from joomla 3.10 and on a clean setup of joomla 4. Both with the same results.
              Apache 2.4.41 on Ubuntu 20.04.3
              PHP Version 7.4.22 fpm-fcgi
              Joomla 4.0.4
              T4 plugin for Joomla 4 versions 2.0.7 and 2.0.8
              tpl_t4_bs5_blank_1.1.2
              Quix 4.1.0 for Joomla 4
                8 months later
                saguaros Hi team, any update on this? I'm still having problem with Quix loading after T4 is installed.
                I tried setting "Template Front-end editor" to "Full positions layout" and updated Quix 4 and T4 to the lastest version, but nothing works. I also tried older version of Quix (2.7.9) as well as T4 1.0.7, but can't get it to work.
                Quix 2.7.9 with latest T4 2.1.4, I can load editor and create content, but it will not display in the front end.
                Quix 4.2.0 with latest T4 2.1.4, Quix editor shows only loading (back end) and just halt there.
                Any solution to this friend?
                  markmail Could you submit a new topic and share the login info of your site eg: URL + super admin account so I can check directly?
