thank you very much. I did it.
One information for the others, if you need to change the default map zoom or other options, then change line 102 in default.php
{jaosmap locations='{"location":<?php echo $nameLocation; ?>,"latitude":<?php echo $latitude; ?>,"longitude":<?php echo $longitude; ?>,"info":<?php echo $nameLocation; ?>,"icon":{"0":""}}' zoom='15' map_width='1000' map_height='840' center='first' }{/jaosmap}
