Hi I have attached 2 screenshots showing how bad related products works on this template, please check
this is the link https://dmozi.com.au/index.php/phones-tablets-wearable/samsung-galaxy-watch-4-40mm-black-detail
Hi dmozi313
You can try with this custom CSS:
.product-related-products .product-field-display a img { max-height: none; max-width: 100%; }
saguaros I have provided the admin details, can you please help with that, as im not sure where to find it
dmozi313
For custom CSS code, you can simply create a new css file called 'custom.css' in CSS folder of template.
I created and updated for you:
/templates/ja_megastore/css/custom.css
Kindly check.
saguaros Thanks, its fixed, you are life saver 🙂
