I created a support ticket and then realized it might be best to post on the forum - my apologies if this is incorrect.
Hello Support
I downloaded your T4 Framework for Joomla 4 quickstart and found a scrolling problem working in Admin --> Navigation --> MegaMenu. Kindly see the attached image.
The "Menu Item options" popup does not scroll.
The popup window cannot be moved.
It is impossible to get to the lower down menu items.
My website is currently on localhost, in an advanced stage of development and I would hate to start all over.
How do I enable the popup window to scroll?
Can you assist?
