did anyone knows why this happend? i think the css code doesn't work.
Hi kblubis
It relates to the layout /menu class used for that menu module in footer.
I added for you, kindly check.
should i add it to every module i create for footer? anyways thanks a lot bro
kblubis That class helps the menu to have 2 columns style. If you want the same style, you can add the same class for other menu module.
how about this :
that module named footer module, why is that module like that? does the css won't work well? thanks
kblubis As I mentioned above, the class cols-2 is used for menu module, not all other modules.
For the contact module, you will need another module in 'footer-1' so it can look like our demo site. I put a Latest Articles module there, kindly check.
