how can I get polish letters in the Gavick Infinity template. At the mobile version, there is no letter, when it comes to polish "ż, ś, ć" etc.
    Hi dublasso
    I checked your site in my iphone device but these characters are still showing correctly:
    Could you check again?
      saguaros
      As you can see polish letters are smaller than other and it seems it's not the same font. Below my screenshots from android Samsung S9 (I've checked it on other android devices and it looks the same).
        dublasso
        This template uses Prata font, not sure if your Android supports it or not. Could you try with another device to see how it goes?
          saguaros
          As I mentioned - I' ve checked it on other android devices, and it looks the same (blank instead of polish letters on android, "smaller" font on my windows 10 notebook).
          Mabye you could give me an advice how to change this font, so it looks similar and it is more popular on different devices (IOS, Android, Windows).
            dublasso It also depends on the font you want to use supports Polish or not, which font you'd like to change to?
            dublasso You can go to Backend >> Templates >> Fonts tab and add this font as you wish:
            //fonts.googleapis.com/css2?family=Playfair+Display
            2 months later
            Thank you for your support. I've changed the font and now it looks ok.
            The last question is to change the Main Menu font size. I found your tutorial (form year 2015), but I can't implement in this Infinity template.
              Hi dublasso
              You can override by this css rule:
              #gkHeaderNav .gkMainMenu .gkmenu.level0 > li > a, #gkHeaderNav .gkMainMenu .gkmenu.level0 > li > span {
              	font-size: 11px !important;
              and change to the font size as you wish.
              Yes, yes, yes. It works :-) Thank you very much!!!
