Need to replace the Footer Module / Code after botched editing adjustment with "mod_footer.ini".
Getting the following error in footer with JA Blocck template on Joomla 4:
MOD_FOOTER_LINE1
MOD_FOOTER_LINE2
*Will also need the path for any adjustments please ... unless you can provide an installable footer module
Thanks in advance, should be able to handle this myself. No need for Admin Credentials
