Hi Pankaj
If you login and go to any group on the site you will see that the Activities/Group Detail panel doesn't render automatically any more
If you then click on Activities or Group Detail it then renders okay
As background - Akeeba suggested I upgrade to PHP 8.0.13 which I did then I noticed this issue so I dropped back to 7.4.26 but the issue remains (the system is hosted on Plesk) - screenshot of the blank panel attached
Any advice?
RG
