HI,
I wrote you few months ago about a sticky menu issue that didn’t stay fixed on mobile phones ( https://www.joomlart.com/forums/d/35510-problem-with-sticky-menu-on-mobile-phones ), this problem was only visible on forum page and only on mobile phones.
You kindly solved this problem by modifying templates/buildr/tpls/blocks/scripts.php file and adding this code:
I just noticed that the same issue has coming back again, but this time only on tablets.
Could you please check again the code you changed?
Here a short screencast to illustrate the problem: http://u.pc.cd/oYF
Thanks a lot for your help,
Lorenzo
