I have installed the JA Ego Template (Quickstart)
Now I have problems to install the necessary Modules/Plugins . Alwas the same error msg (attached).
Pls answer all questions and solve the problem.
1. Why all the nessecary Modules/Plugins are not installed in the Quickstart Package?
2. Is it not possible to have also T4 Page Builder alredy installed with this Packages (or prepare one more where it's included)?
3. Please send me a detailed instruction to solve the problem and tell me which Modules/Plugins I have to install after I downloded a Template Package (or write it into the documentation of the template. I have do do much more websites...
    awiance
    On your website when you installed a quickstart it already has all plugin and module that is on the download page.
    So there is no need to install them again.
    In your error screenshot it appear you are installing quickstart package via Joomla that is not possible as it is not an extension.
    You can let me know the Module name which is not installing on your site only so i can check that specific one for you.
      Ninja
      As I wrote, please answer all question!!
      1. I'm not able to install T4 Page Builder. I gave the login data, please check.
        awiance
        1. T4 Page builder is installed on your site. There is no error found in installation of T4 builder package.
        2. It is not possible as JA EGo quickstart does not came with T4 builder install
        3. Since this thread is on JA Ego template there is no special instruction for it as you already installed quickstart package that came with sample data already to show site like in the demo.
        I still have problems -> see attached files.
        Ans I still don't get the idea of Joomlart to build a website. Especially the correlation between a Template e.g. Ja Ego), T4 Page Builder and T4 Framework. Can please give me someone a structure?
          awiance
          T4 page builder is component to use to created pages from built in block it work like an editor if you want to make site faster check here :https://www.joomlart.com/t4-builder/t4-joomla-page-builder
          A Joomla template is normal template like any Joomla template that came with own style for Joomla pages with modules and article pages.
          For template part kindly open template style /administrator/index.php?option=com_templates&view=style&layout=edit&id=9
          You can see how T4 framework here https://www.joomlart.com/documentation/t4-framework
          But still you don't give me the idea how to work with Joolmart.
          Is it not possible to have a combination of Template (e.g. Ja Ego), T4 Page Builder and T4 Framework?
          If yes, what to install first?
          Thanks.
            awiance But still you don't give me the idea how to work with Joolmart.
            You should provide details of issue. As there is nothing like this. The working is same as Joomla
            Everything is installed on your site already please
            check it.
            You can use it as well T4 Builder can be used on the template too .
            If you stuck on something kindly let me know
            You can refer to docs I shared that are to understand and change setting in both template and Builder.
            So I studied the docs and also made some samples.
            I like to use T4 Pagebuilder and T4 Framework, whithout a template (only basics).
            But if I install T4 FW (quickstart) and the I installed T4 PB I had problems to modify the articles. I toggled them to T4 PB but content was missing after toggling.
            Don't you have a bundle (quickstart) including T4 FW and T4 PB?
            Or wheres the problem?
              awiance whithout a template
              You have to use 1 Joomla template as template must required on Joomla site to load frontend.
              awiance T4 FW and T4 PB?
              The quickstart of T4 page builder has both. Articles are normal Joomla articles and you can edit them on your own as well wit T4 page builder.
              I am moving this thread to T4 page builder since the topic is changed now.
