After the update 4.8.1, the backend does not work. The menu does not open.
Backend does not work
Kristina1982 changed the title to Backend does not work.
Kristina1982
There is no such issue found in new version.
Can you edit fields in the first post and submit a temp super user login for staff?
Ninja
Hi, edited.
Kristina1982
Kindly clear browser cache and check again it is working fine
Ninja Thank you very much!
Kristina1982
You are welcome!
Ninja locked the discussion.
