I am working on a local server with your shop and buy template and joomla 3.8.6
I am new working with joomla but still not so new not to be able to publish a product.
I created a new product in VM and there is no way to display it under the category.
All parameters are check according VM and still not visible. Can you suggest me smthg to do? I can´t go forward and the VM tutorial and nothing are the same.
In case this is not working or you cannot help me, what is the way to give the template back. You say money back within 7 days guarantee. I would rather keep it but if it is so complicate to make even a very simple and basic thing I have no interest.
I appreciate an answer. Thank you
