Hi, I'm trying to install quickpackage of JA Blockk but it doesn't install the demo content even though I specify so in the installation wizard. Once I'm in the admin I see this screen. Sorry, installed in localhost so I can't give you access. Can you please check if that package in the download section is ok? Joomla 3 package. Thanks
Hi aletheia1
I just downloaded quickstart package for Joomla 3 of JA Blockk template and installed in my local but it worked normally.
I mean all sample demo packages are showing there.
For what reasons could it be that is not working for me?
aletheia1 Maybe you did not select the sample data when installing?
I did, I made sure I did, but it's not working... something should be writable and it isn't?
aletheia1 It's weird, which PHP version are you using?
I can install and share you the backup file so you can store into your site, let me know the sample data package you want to install: Magazine, Entertainment, Fashion, etc....
Something is definitely wrong with Blockk quickstart, both J3 and J4. It installs OK and frontpage shows "Complete your installation by installing the sample data Your installation is almost done. Access your website administrator and install the sample data (a demo site)." When in backend there's no option for sample data, just regular administration. I tried several times, then installed xampp on localhost and still have the same problem. Then I tried Phio quickstart and it works normally.
Hi zakladadadic
Could you pls share your server's environment so we can replicate this issue?
PHP version MySQL version. ....
I just tried to install in my local host with Mamp but it worked perfectly.
Weird. I tried xampp versions 7.4.29 / PHP 7.4.29 and 8.1.6 / PHP 8.1.6. Same problem with J3 and J4 Blockk quickstart. Also redownloaded files and tried again. Ja Phio quickstart works OK.
zakladadadic I've reported to the team for further checking & update.
I will keep you posted.
UPDATE:
Our team just re-exported the quickstart packages, pls try to download and install again.
It works now. Thank you.
zakladadadic Glad to hear that!
