Hello Hope you can assist me . I am using your JA Elicyon template and everything work fine accept for Virtuamart. Everytime I view anything in the shop and then select any other virtuemart link I need to first clear the joomla cache. I attached a print screen of the actual error. Once I cleared the joomla cache it work fine again but then after I navigate in the store one more time I have to do the same. I also attached the cache modules that needs to be cleared everytime - all of them are virtuemart items.
i disabled all cache options in Joomla but it still give me this error. Any help will be appreciated.
Dana
Hi Dana,
I guess you installed quickstart of this template, right?
I tried to install quickstart package + update Joomla of Virtuemart to latest version but it still works fine.
Could I backup your site and restore in my local to see how it goes?
He,
Yes you are welcome to do that. Let me know if you need other access information form me.
Regards Dana
Yes, I used quickstart for the installation....
danab let me check and will get back to you.
