saguaros Thanks for checking things out and the quick reply.
This is my second attempt at using JA Ego template and having problems with what I'm mixing (template, T4 Page Builder, etc), but yes I'm early in the process. I'll backup images and misc that I've already created and try reinstalling (same as I had to do last time using Ego template for my other client).
Of note, JA Ego template is perfect in many respects offering 4 different models (business, spa, medical, pet) and I'm amazed someone hasn't created an interface that will auto adjust these multi-template designs to automatically setup the business, spa, medical or pet setting needed from the beginning.
Sadly, the problems are probably on my side not understanding your instructions to recreate the base setup, but aren't be just talking 1s and 0s controlled by a database and making these changes quickly using an install script one of your programming geniuses could provide?
Thanks either way, and I'll try the re-start process and let you know how it goes. Sorli...
