Dear team, I need to be able to put a slideshow in Home, with several images that can rotate in a loop and that Ja Custom Search can be seen, as in the example page. Is it possible to do that? Regards Sergio
Hi Sergio,
On our demo site, the search is the main block of the homepage. If you want to add a slide module and put the search over the slide, it will need a different approach. Maybe customize the layout and style for module + search also. It will take time 🙂
A temporary solution that could work for me would be to be able to put Ja Custom Search centered on the frontend and below a slideshow, is that possible? Sergio
The main search form on homepage of this template belongs to the main content block, not a module so you can style it easy to cover another module (slide). As I mentioned you need to customize much to achieve this, there is not temporary solution now unfortunately.
