Hello.
I installed JA Elicyon and today I updated it with the new version uploaded on 17 june by JoomlArt.
Unfortunately it doesn't seems to work with VM4.
I created a menu "Shop" but as I click on it I receive the error:
CALL TO A MEMBER FUNCTION DISPLAYMEDIATHUMB() ON NULL
Prova a visitare una delle seguenti pagine
/var/www/vhosts/atenagalleriadarte.com/httpdocs/templates/ja_elicyon/html/com_virtuemart/sublayouts/products.php (78)
If I change the template, it works. Does anybody know how to fix this?
Thank you
