How to add padding between load more and sidebar-2 position in mobile view.
Chi-K
You can use this custom css:
@media (max-width: 767px){ .t3-content { padding-bottom: 15px; } }
Where do I add this custom css ?
You can put into: /templates/ja_magz_ii (your default template)/css/custom.css (Create this file if it doesn't exist now)
Coming back to this, I tried the code you suggested above but the site still has the load more sticking to the top of the next section:
There is also a padding issue on the first article (leading article) on the left and right as below
You can change above code:
To:
.t3-content {padding-bottom: 15px;}
