Good day,
I have found a few problems on the template, I am hoping that you can help assist with these issues as soon as possible.
On the products pages if there is a next page option to list more products, it doesn't go to the next take and just reloads the page. You can find an example of this under the personal category then drinkware.
The logo size is not applied correctly. I have uploaded the logo as the exact dimension from the original Ja Mixstore logo and for some reason my logo is extremely small. There is another issue of image resizing on the contact us page, the image again is the right dimensions but it is stretched for some reason.
When you navigate on the menu item "shop" there are products listed that is not found on my backend on virtuemart, I have deleted all the sample products but those dummy products are still there. I need to remove those products somehow and display a mixture of all the products (not categories) that is found on the website.
Some products display a "add to cart" option and some display "view product details" option, I need to change all the products to show, view product details
I have installed a plugin to upload images on the product page (for custom printing), but when I want to add the module to be displayed in the virtuemart position "addtocart" the position is not listed in the module. I can change this to another position as well but then it displays everywhere on the website, is there a position I can use that it will only display on the product information (when you actually view the product).
When viewing a product there is a print and email option but the icons does not display for some reason.
How do I index my products into virtuemart, when I search for any of my products I just get a no results found return.
I don't know how I can change the layout of the products and categories, you had a few options that was configured with the template but I can't see anywhere where you can allocate that layout to your products and categories. The layout that I am looking for is "shop - grid 4 cols w/filter"
I noticed that after installing updates for extensions and template and changing my PHP version to 8, I can no longer open the shipment methods in Joomla, as soon as I click on a shipment method, it loads and gives met a 503 service unavailable error.
The email being sent out to new registering users does not display the correct details, I looked at the emails configured in the template (ie. [Name], [Confirmation Link] etc), when sending the email it doesn't replace it with the customers details. So essentially the email that the customers receive looks the same as in the configuration window in Joomla.
Thank you in advance for helping with all the issues. Kindly let me know if you have issues with the FTP login, I might have to approve a connection from your country to be allowed (please specify which country you are logging in from), else South Africa is approved at the moment, if you can use a VPN.
Kind regards,
Daniel
