Good day,
Some of my products display a "add to cart" option and some display "view product details" option, I need to change all the products to show, view product details, can you kindly assist as to why its doing this and how to fix it (note there is no difference in product setup between the two, ie. parent products)
Thank you in advance for helping with all the issue. Kindly let me know if you have issues with the FTP login, I might have to approve a connection from your country to be allowed (please specify which country you are logging in from), else South Africa is approved at the moment, if you can use a VPN.
Kind regards,
Daniel
