Hello I'm having a problem with the links generated for Easyblog by NSP it is like website.com/component/easyblog/article
But i want it to be like website.com/menu/article
I had it working normally on joomla 3
Links problem
I would like to inform you that Stackideas team applied a fix about my problem if you want i can share the fix with you so you can add it on the next NSP release.
haonas Hi
We'd really appreciate the fix if you don't mind sharing
- Edited
Replacing view.php with the the following code will solve the issue. (sorry but i was not allowed to attach php file)
JoomlaFolder/modules/mod_news_pro_gk5/tmpl/com_easyblog/view.php
`<?php
- This View is responsible for generating layout parts for the com_content data source
- @package News Show Pro GK5
- @Copyright (C) 2009-2013 Gavick.com
- @ All rights reserved
- @ Joomla! is Free Software
- @license - http://www.gnu.org/licenses/gpl-2.0.html GNU/GPL
- @version $Revision: GK5 1.3.3 $
// access restriction
defined('_JEXEC') or die('Restricted access');
class NSP_GK5_com_easyblog_View extends NSP_GK5_View {
// article text generator
static function text($config, $item, $readmore) {
if($config['news_content_text_pos'] == 'disabled') {
return '';
if($item['text'] === '') {
$item['text'] = $item['text_alt'];
$item['text'] = NSP_GK5_Utils::cutText($item['text'], $config, 'news_limit');
$item['text'] = static::textPlugins($item['text'], $config);
$link = static::itemLink($item, $config);
if($config['news_text_link'] == 1) {
$item['text'] = '<a href="'.$link.'" target="'.$config['open_links_window'].'">'.$item['text'].'</a>';
$class = ' t'.$config['news_content_text_pos'].' f'.$config['news_content_text_float'];
$output_html = '<p class="nspText'.$class.'">';
$output_html .= $item['text'];
if($config['news_content_readmore_pos'] == 'after') {
$output_html .= ' ' . $readmore;
$output_html .= '</p>';
return $output_html;
// article image generator
static function image($config, $item, $only_url = false, $pm = false, $links = false){
if(!($config['news_content_image_pos'] != 'disabled' || $pm || $links)) {
return '';
$IMG_SOURCE = '';
$item['title'] = str_replace('"', """, $item['title']);
$uri = JURI::getInstance();
$IMG_LINK = static::itemLink($item, $config);
if(trim($item['image']) != ''){
$image_path = str_replace(array('user:', 'post:'), '', $item['image']);
if(stripos($item['image'], 'user:') !== FALSE) {
$IMG_SOURCE = 'images/easyblog_images/' . $image_path;
} else {
$IMG_SOURCE = 'images/easyblog_articles/' . $image_path;
} else {
// set image to first in article content
$IMG_SOURCE = NSP_GK5_com_easyblog_View::getImageFromText($item['text']);
$full_size_img = $IMG_SOURCE;
if($config['create_thumbs'] == 1 && $IMG_SOURCE != ''){
// try to override standard image
if(strpos($IMG_SOURCE, 'http://') == FALSE) {
$img_file = NSP_GK5_Thumbs::createThumbnail($IMG_SOURCE, $config, false, false, '', $links);
if(is_array($img_file)) {
$IMG_SOURCE = $uri->root().'modules/mod_news_pro_gk5/cache/'.$img_file[1];
} elseif($config['create_thumbs'] == 1) {
jimport('joomla.filesystem.file');
if(is_file(JPATH_ROOT.DS.'modules'.DS.'mod_news_pro_gk5'.DS.'cache'.DS.'default'.DS.'default'.$config['module_id'].'.png')) {
$IMG_SOURCE = $uri->root().'modules/mod_news_pro_gk5/cache/default/default'.$config['module_id'].'.png';
} else {
$IMG_SOURCE = '';
return NSP_GK5_com_easyblog_View::getImageHTML($only_url, $IMG_SOURCE, $links, $config, $IMG_LINK, $full_size_img);
// article information generator
static function info($config, $item, $num = 1) {
// %AUTHOR %DATE %HITS %CATEGORY
$news_info = '';
$author = '';
if($num == 1){
if($config['news_content_info_pos'] != 'disabled') {
$class = 'nspInfo1 t'.$config['news_content_info_pos'].' f'.$config['news_content_info_float'];
} else {
if($config['news_content_info2_pos'] != 'disabled') {
$class = 'nspInfo2 t'.$config['news_content_info2_pos'].' f'.$config['news_content_info2_float'];
if(
($config['news_content_info_pos'] != 'disabled' && $num == 1) ||
($config['news_content_info2_pos'] != 'disabled' && $num == 2)
$news_info = '<p class="nspInfo '.$class.'">'.$config['info'.(($num == 2) ? '2' : '').'_format'].'</p>';
$info_author = '';
// load author data only if necessary
if(stripos($news_info, '%AUTHOR') !== FALSE){
$author = htmlspecialchars($item['author_username']);
$author_html = '<a href="'.urldecode(JRoute::_('index.php?option=com_easyblog&view=blogger&layout=listings&id=' . $item['author_id'])).'" target="'.$config['open_links_window'].'">'.$author.'</a>';
if($config['user_avatar'] == 1) {
// load necessary Easy Blog Route Helper and avatar helper
require_once (JPATH_SITE.DS.'administrator'.DS.'components'.DS.'com_easyblog'.DS.'includes'.DS.'utils.php');
require_once (JPATH_SITE.DS.'administrator'.DS.'components'.DS.'com_easyblog'.DS.'includes'.DS.'easyblog.php');
require_once (JPATH_SITE.DS.'administrator'.DS.'components'.DS.'com_easyblog'.DS.'includes'.DS.'avatar'.DS.'avatar.php');
$post_data = EB::post($item['id']);
$blogger = $post_data->getAuthor();
$info_author = '<span><img src="'.$blogger->getAvatar().'" alt="'.$author.' - avatar" class="nspAvatar" width="'.$config['avatar_size'].'" height="'.$config['avatar_size'].'" /> '.$author_html.'</span>';
} else {
$info_author = $author_html;
$info_date = JHTML::_('date', $item['date'], $config['date_format']);
$info_hits = JText::_('MOD_NEWS_PRO_GK5_NHITS').$item['hits'];
$info_rate = '';
$info_category = ($config['category_link'] == 1) ? '<a href="'.static::categoryLink($item).'" target="'.$config['open_links_window'].'">'.$item['catname'].'</a>' : $item['catname'];
$info_comments = JText::_('MOD_NEWS_PRO_GK5_NO_COMMENTS');
if(isset($item['comments'])) {
if($item['comments'] == 1) {
$info_comments = JText::_('MOD_NEWS_PRO_GK5_1COMMENT');
} else if($item['comments'] > 1 && $item['comments'] < 5) {
$info_comments = $item['comments'] . ' ' . JText::_('MOD_NEWS_PRO_GK5_MORECOMMENTS');
} else if($item['comments'] >= 5) {
$info_comments = $item['comments'] . ' ' . JText::_('MOD_NEWS_PRO_GK5_MUCHMORECOMMENTS');
$info_comments_short = 0;
$link = static::itemLink($item);
$info_comments_short = $item['comments'];
$info_comments_short = '<a href="'.$link.'" target="'.$config['open_links_window'].'">'.$info_comments_short.'</a>';
$info_tags = '';
if(isset($item['tags']) && count($item['tags']) > 0) {
$i = 0;
foreach($item['tags'] as $tag => $id) {
$link = urldecode(JRoute::_('index.php?option=com_easyblog&view=tags&layout=tag&id=' . $id));
if($i == 0) {
$info_tags .= '<a href="' . $link . '" target="'.$config['open_links_window'].'">' . $tag . '</a>';
} else {
$info_tags .= ', <a href="' . $link . '" target="'.$config['open_links_window'].'">' . $tag . '</a>';
$i++;
// Featured label
$info_featured = '';
if(stripos($news_info, '%FEATURED') !== FALSE && $item['frontpage'] == '1') {
$info_featured = '<strong class="is-featured">'.JText::_('MOD_NEWS_PRO_GK5_FEATURED').'</strong>';
$news_info = str_replace('%AUTHOR_NAME', $author, $news_info);
$news_info = str_replace('%AUTHOR', $info_author, $news_info);
$news_info = str_replace('%DATE', $info_date, $news_info);
$news_info = str_replace('%HITS', $info_hits, $news_info);
$news_info = str_replace('%CATEGORY', $info_category, $news_info);
$news_info = str_replace('%RATE', $info_rate, $news_info);
$news_info = str_replace('%COMMENTS_SHORT', $info_comments_short, $news_info);
$news_info = str_replace('%COMMENTS', $info_comments, $news_info);
$news_info = str_replace('%TAGS', $info_tags, $news_info);
$news_info = str_replace('%FEATURED', $info_featured, $news_info);
} else {
return '';
return $news_info;
// article link generator
static function itemLink($item, $config = false) {
static::ebExist();
if(isset($item['overrided_url'])) {
return $item['overrided_url'];
return urldecode(EBR::_('index.php?option=com_easyblog&view=entry&id=' . $item['id']));
// category link generator
static function categoryLink($item) {
static::ebExist();
return urldecode(EBR::_('index.php?option=com_easyblog&view=categories&layout=listings&id=' . $item['cid']));
// user link generator
static function authorLink($item) {
static::ebExist();
return urldecode(EBR::_('index.php?option=com_easyblog&view=blogger&layout=listings&id=' . $item['author_id']));
// require Easyblog file
static function ebExist()
$file = JPATH_ADMINISTRATOR . '/components/com_easyblog/includes/easyblog.php';
if (!JFile::exists($file)) {
return;
require_once($file);
// EOF
haonas Thank you for sharing this!
Kudos to Stackideas team!
