Hello. I m trying to make the module more close each other, the contact and the social align to the left side and the phone and language more right side (close each other) , instead of https://prnt.sc/yUms6L34o4dO like I have it in the live site now : https://prnt.sc/GSxH8FjiCNHV . But the configuration not helps me : https://prnt.sc/DzTu9SGtFjqr Any advice please? Thanks
When you set the column like that (for example: 2 grids) it will add the equivalent width for that section so it doesn't show closely. If each module has less content, you can put into the same position and customize style for it.
