Hi, I'm having a problem with the masthead module. The images are not showing up on the pages, I have checked the masthead version, cleared the cache but the images used on the Our Roots and How can you Help pages will not change. I have checked the template and even made a copy JA Default(2) but nothing happens. Even when I remove the page from the module and use an image that is assigned to the page the image will not show. However this is not the same for the contact us page even though I am using the same template for both pages
Hi, I sent this post about a day ago and haven't had any response at all
It seems that you're using old version of template, you can take a full backup of your site and update latest version for template first.
Hi Saguaros
thank you very much, I've done that and it has worked
