Joomla 4 After i made translation, i can`t select menu in Site template styles and language switcher display only EN. Problem with menu what was added automatic by translation component.
liubov Could you check the provided admin account again? as I can't access with it now.
And if I understand the issue correctly, you can't select main menu for EN for the current template style of EN, right?
saguaros for any language if it created by translation component
login page https://dev.trophy.travel/administrator/index.php same credential.
That dropdown menu list will show menu that has active item only. At this moment, all menu items (of menus that don't appear in the list) are expired.
I just created a test menu item and you can see the menu will show in the list:
