Code I insert into Custom Code before HEAD in T3 with J4 isn't visible in the code on the frontend?
Any advice how to get this working?
Kind regards
Thomas
Hi Thomas,
You can share the super admin account of your site, I will check the code and see what's wrong.
Sure, fields are updated now :-)
Hi Thomas
I checked the custom code section in template but nothing filled there. Could you add again?
I had to hardcode the content to get it to work.
Feel free to add something to test with 🙏🏻
Hi Thomas,
I changed the order of T3 plugin under Plugins manager and the custom code should be fine now.
I added sample code and it shows normally on frontend.
