Hello GURU Support,
i have a problem with the reviews... i created a review for the course: https://www.traicons.de/index.php/ijoomla/guruprograms/1-traicons-information/2-traicons-information-wie-buche-ich-einen-kurs but it seems, that the review has no function. (see pic1)
In the review window guru doesn´t show the rated stars. (see pic2)
Can you check it please?
Regards André
Hi André,
Could you share the account so I can see that review?
Good morning saguaros, i already gave you the site administrator infos. I wrote another review with the support account so you should see the problem with the link from above.
King regards André
colossos Hi, There is an issue with review layout. You can use this package to fix it Kindly check.
https://drive.google.com/file/d/1kF-hCBNEmDMSURkEPPZ3nesC5NNoy4sS/view?usp=share_link
HI André,
Could you share the FTP account also? I will check with our team on this.
Hi, all problems are fixed. Thank you very much.
King regards. André
