Hi there, first of all I want to apologize for my English, I come from France. I installed T4 framework and I love it, I created my template locally and I would like to know if it is possible to round the corners of the frame of the main body component and also to increase the size of this framework ?? Thanks in advance for the help
Not sure how you're setting up your site, could you share URL of that page and screenshot of how you want it should be?
Normally, you can add for the div you want, for example:
div#t4-main-body { border-radius: 30px; }
Hello, thank you for your help, my site is on local in my computer. Where i put the code , in wich file ? div#t4-main-body { border-radius: 30px; } Thank you
You can put into file: root/templates/your_default_template/css/custom.css (Create this file if it doesn't exist now)
I have follow your instructions: in C:\wamp64\www\caphg\templates\t4_bs5_blank\css i have created the file custom.css and put on it the code , saved the file, clear the cache, refresh my page but it's not working. The corners are the same as before. Thank a lot for your help Pat
Hello, my problem is solved, it was enough simply to fill in "rounded border" in the extra class box. Thanks for your help. Merry Christmas to everyone
