After the last extension update, I have a problem with:
  1. The Ja_Accordin module is always open
  2. Ja_Content slider module does not display content
As I can see that there is JS conflict on homepage of your site now so it may cause the issue, could you share the correct URL to access backend of your site and the FTP account so I can check?
Thanks for the info, let me check and will get back to you.
5 days later
midhat I'm checking with our developer for these 2 extensions, kindly wait.
Hi, midhat
These issues were directly fixed on your site. These files change:
root/templates/ja_obelisk/html/mod_jaaccordion/default.php
line 48
root/modules/mod_jacontentslider/assets/js/ja_contentslider.js . I replaced the old file <changed name into: ja_contentslider-1.js> to a new file.
You kindly check.
defaultphp.zip
1kB
ja-contentsliderjs.zip
2kB
