I am using this module in a Joomla 4 website and I am getting the following issues when I'm editing the module:
  1. When entering data in chart configuration fields, selecting fonts, etc the module suddenly closes.
  2. Some of the configuration options do not appear. Sometimes clicking around the area make them appear on the screen.
As you can see from the attached image - 'Exploding Slices' and '3d Chart' toggles are not there.
When clicking in the area the toggle for the '3d Chart' option appeared. But it doesn't always appear.
Another example of a missing toggle:
  1. The chart preview is not always rendering on the module.
    Hi chamira
    Thanks for your report! I've forwarded to our dev team for further checking and update.
    Kindly wait.
    a month later
    Hi, chamira
    For the issue Not always showing up radio buttons, I fixed it. You are able to replace the file mod_jagooglechart_2.xml.
    But the other issues I carefully test on local and our server, it normally works well.
    You kindly check and response to us.
    mod-jagooglechart-2.zip
    5kB
    Regards,
