When I am checking the site with browser console it gives me 10 errors.
The 4 errors are "Unchecked runtime.lastError: The message port closed before a response was received." And I can see the same errors on DEMO example on your web site.
And I have 6 errors
Failed to load resource: the server responded with a status of 404 () /plugins/system/vendor/fontawesome-free/webfonts/fa-solid-900?format=woff2
Failed to load resource: the server responded with a status of 404 () /plugins/system/vendor/fontawesome-free/webfonts/fa-brands-400?format=woff2
Failed to load resource: the server responded with a status of 404 () /system/vendor/fontawesome-free/webfonts/fa-solid-900?format=woff
Failed to load resource: the server responded with a status of 404 () /plugins/system/vendor/fontawesome-free/webfonts/fa-solid-900?format=ttf
Failed to load resource: the server responded with a status of 404 () /plugins/system/vendor/fontawesome-free/webfonts/fa-brands-400?format=ttf
Could you please help me to correct these errors.
You can go to template >> Global Settings >> Addons: if you don't use iconmoon, pls disable that option and clear all caches:
8 days later
