I use Gk Blend template on my joomla 4 site (manual installation)
I have a few questions about Homepage
1) under the header there is a lot of white space, I want to use only 1 image 1920x740 px instead of the slider proposed as an example of GK BLend.
On google browser with webmaster tools I see that whitespace is part of the gkHeaderMod :
<div id="gkHeaderMod" class="gk-clearfix">
Please can you recommend custom css script or other solution to remove white space under header image
2) on HOMEPAGE Services section - The section is built with News Show Pro GK5 module -with 3 Images and text in mousover
I followed the documentation instructions and I set everything like written in the instructions, but it doesn't look the same as your example:
-text that appears with mouseover with the brown background is larger than the photos and offset
- does not appear link read more
How can I fix it?
Thank you
Mary
