jan007 Hi
Could you try to disable 3rd party extensions on your site first or contact Virtuemart support for help? as I tried to assign a VM page on your site to 'Cassiopeia' - a standard template of Joomla but the same issue happens. That means the issue doesn't come from GK Blend template. You can check and see the same.
