Hi I downloaded JA Atoms with Quick Start.
I have installed Eshop and created a filter and when I select a category option the filter does not seem to work ie: it keeps displaying all items from all categories and and not products from the category selected.
I have used the same filter options from the existing filter created with the the quick start files but chose eshop not virtuemart.
Is there a setting I am missing?
    jacquievc Hi
    I just created a new menu item to show the filter with EShop but it worked: /index.php/filter-eshop
    Could you check?
    Hello thankyou, I can see that your menu item is working.
    Hopefully I can replicate what I want without breaking your menu item!
      hidden content
      I added this custom CSS so it displays better now:
      .ja-megafilter-wrap .cols-3 .product-item {
          max-width: unset !important;
      JA Atoms offers Virtuemart integration only, it doesn't have custom style for filtering EShop. If you want it displays the same as Eshop page, you have to customize it.
