The home page (now deactivated) of the Ja Coach template no longer displays the images of the various modules. It always worked but now something went wrong. Also the footer block does not display the modules uniformly on all pages. For now I have I created a home with Sp Page builder, but I want to go back to Ja Coach home.
Can you please fix this?
Thank you
    lableo Hi
    As I can see that you have 2 home items now, which one you want to use so I can check?
      hidden content
        hidden content
        I deactivated the default "home" page because it causes problems. For now the default page "Il Caffè" built with Sp Page Builder Pro works.
        I prefer to make the site work with your ecosystem but for me it is extremely difficult to work with your page editor which I find unintuitive.
        With the ja_coach - Default template, installed with quikstart, almost a year ago, I have several problems. I updated it to the latest version, but didn't fix it:
        1- The Hero module doesn't work
        2-Canvas for mobile doesn't work
        3- the footer block does not show the same positions in all assigned pages. The blog page works on the desk in a single column.
        4- the Top edge on the desk and on the furniture touches the logo, more space should be given
        5 - I need to use the masterhead position. I tried this feature in the template but it gives problems
        I kindly ask you to intervene on the site with the credentials that I have already sent you. I have been your customer for more than 10 years. The site is in production I would not like to have problems with my client
        Thanks for the support
        Leonardo
        Hi Leonardo,
        Pls help to separate your questions in different topics so it'll be helpful for community if others face the same issue.
        About the top margin of logo, could you share screenshot illustrating how you want it should be? as it looks fine from my end:
        I placed an image in the masthead position and now it seems to work correctly.
        I have some other problem which I will describe to you right away in another post.
        Thank you
          lableo
          Regarding the margin, as you can see from the home page that I am attaching, the page overlaps the logo, you need to increase the margin with respect to the menu
