Hi all, I have created a module which works when published to section-9 of the SEVEN template, but will not show when loaded into the article. See here (where code for loadposition of slideshow is in article but does not show; yet same module slideshow works when module is published to section-9) https://cherries.org.au/the-vca/conferences/conference-2017 Any idea how to get a module to display in the article area?
Thanks, Nick
Hi @NickMo1
Usually, modules are added in the full text but since you didn't have a readmore tag, they were added in the intro text. I have updated it for you.
Kindly check and let us know if you need further helps. 🙂
Sorry, I was not aware that you were changing things while I was also doing the same. So I am not sure if you fixed things or if I removed your changes and implemented my own. Could you tell me what you did please, so I don't have this issue again.
Thanks.
OK, thankyou. I have just realised that you added the readmore to the page. It's all good. I will remember that for next time.
Let us know if you need any further help 🙂
