Good day!
I'm having a problem with the padding on mobile article pages. Please see the screenshot below.
LINK: https://myuap.report/history/types-and-kinds-of-alien-encounters
Would it be possible to supply me with the CSS code in order to make the article text a bit more readable? Otherwise, if there is a setting somewhere that I've missed that's causing the text to be squished up like this, I'd be most happy to take advice.
Thank you!
Todd
Hi @toddjharrison73
I have updated style to fixed this issue on your website. You can see the custom code when click to the Edit custom css button.
@media (max-width: 576px) {
  div.item-page.com-content-article {
    padding-left: 1.5rem;
    padding-right: 1.5rem;
Regards,
Thank you so much @cssyeah !! I really appreciate your help.
You can go ahead and mark this one resolved, or whatever you need to do.
Thank you again!
Todd
phinb locked the discussion.
