I do have a problem with cathegory blogs. When I open an article with the "read more"-button then every module from the previous page is still visible. (for admin: for example have look at the cathegory blog Team on the homepage)
This issue causes only with cathegory blogs and only after a certain time. When I restore a backup then the issue seems to be solved but after about an hour it happens again. I hope it's a user error :-)
Thanks for your help!
hidden content
I think my problem description is a little unclear. The problem comes in combination with the module news show pro GK5 and a cathegory blog as shown on the example start page of the infinity template with the module "our team..."
I'm not familiar with native language on your site, do you mean this section?
I tried to click an item and it opens normally.
Yes, I mean this section. The reason why it opens "correctly" is that I created a new cathegory blog menu item. But then the features of the template (sidebar with round picture and joomla fields) are not working. Before this new menu item it opened but with all modules of the homepage.
You can see the issue on the page Unternehmen as well . When you scroll down you can open an article out of the cathegory blog in combination with News Show Pro. There you can see that all modules of the page "Unternehmen" stay opened.
    5 days later
    ahierholzer In Joomla, articles must be assigned to a menu item so that it can open correctly, otherwise, it will keep showing on homepage like that.
