GK Spotlight - problem with translate I need translate in article part with "In the article". When I can translate it?
miroseget Hi
You can override this language constant: TPL_TITLE_LEAD_LABEL
Thank You very much. And the last problem I have with translate "more news" (please see photo). I dont see it in web modules. Please help me.
miroseget It's page heading, you can go to menu item settings of your site's homepage >> Page Display tab >> and change the text there:
ThankYou very much. Super.
But I have one another problem. When I can change photo in profile, joomla change adress to photo and dont display photo in frontend (system automatically change adress from short to long). Coult You help me please? Please see pictures
miroseget Could you share the URL of that page on frontend so I can check?
and share that super admin account also.
miroseget When I can change photo in profile, joomla change adress to photo and dont display photo in frontend
But which page that your profile photo doesn't show? could you share the URL of that page so I can check?
saguaros I have it only on localhost in my computer
miroseget Could you put your site online and share me the login info so I can check it directly for you? as I can't replicate this issue at my end now.
miroseget Could you check the admin URL again? as it doesn't show the correct admin login page.
saguaros check it again, please
Could you share the URL of page where I can see the issue from frontend? I tried to login: /index.php/your-profile?view=login but the URL not work.
saguaros chek it now please, I dont public it.
Hi, miroseget Thanks for providing the information. I will check and get back to you soon so please be patient.
Regards,
vangogh ok. Thanks.
miroseget It's a bug in template, our team is looking into it, pls stay tuned.
