1) Video display on the mobile version.
It was necessary to crop the video correctly, the "play" button is completely off. https://prnt.sc/vJUUHoslJ4C6
2) OTENTHIKE logo on mobile and computer version
The OTENTHIKE logo must allow reference to the home page, especially for the mobile version. look please : https://prnt.sc/m83rNJMgTqvM
could you help me please ?
    ludo974 Hi
    1 - I updated this custom CSS for that video section for you:
    /*Added by JA Support*/
    @media (max-width: 480px){
    .t4-section .section-6-r, .t4-section .section-7-r {
        padding-left: 10px !important;
    div#acm-video-104 {
        text-align: center;
    2 - I see the logo on mobile vs desktop looks the same now, could you check again?
    Thanks for you help,
    I think you misunderstood my question "2"
    I would like that when the Internet user clicks on my logo whether on the mobile version or on the computer, it should refer to the home page of the site please
    3 /
    moreover, I would like that on the mobile version of my site it also appears these modules which represent the contacts of my company, how should it be done please?
    https://prnt.sc/4cuIrIOfyQ0k
    Coud you help me please ?
      ludo974 As I can see that you create menu items for logo specific and they have type of 'Menu Heading' menu item type.
      However, this type doesn't have link, you should consider to change to another menu type link 'URL' for example, and put your link there.
      Ok, I understand, and I corrected according to your advice and it works thank you very much you are great! were you able to find a solution for this please?
      **_3 /
      Coud you help me please ?_**
      You can configure to show/hide these module positions in responsive layout settings of template:
