Hi. I don't understand why there are articles where a module that appears correctly 90% of the time appears at the bottom of the page: https://robustiana.com/432-como-activar-una-yubikey-en-ubuntu
Is not related to a menu item or item category because other articles in the same condition show the module to the right as expected.
Is that some issue with the template?
Hi eera5607, I have helped you add the following CSS code to the Tools > Custom CSS and resolved this issue, you can check your site now.
.view-article .t4-section-inner .row { display: -webkit-box; }
Thank you. Solved.
