saguaros Hi Saguaros, that's unfortunate indeed, as we only learned of this well into our site's development. As is, the mobile UIX is unusable and we may have to change templates (start from scratch), something I'd like to prevent if possible.
Regarding laptop arrow-key scrolling, I asked Open AI about the issue it seems the JavaScript solution is simple enough. Can you at least point the right files to change, so that I can go ahead and experiment with solutions?
As for the mobile one finger/two finger issue, can you also point to the right files to edit, and possibly explain why the problem solves it self once the device changes horizontal/vertical device position?
Thanks for any help you can provide. As you can imagine, these two issues dramatically effect the quality of the template. As you might also imagine, AI might be a perfect tool to provide a solution much sooner/simpler than expected.
