JA System Designit Plugin doesn´t work with J4, I enabled the plugin but it is not for J4, so my site crashed. No problem, as I could disable it in database and then I could deinstall the plugin.
It is only for info :-) Best regards Petra
Hi Petra,
This plugin integrates a design service but it's terminated so you don't need to use / install this plugin in J4.
